http://www.ebay.co.uk/itm/RAT-HOTROD-VALVE-AMP-SPEAKER-DUMMY-LOAD-HEADPHONE-AMPLIFIER-LINE-OUT-BOX-16-OHMS-/351120597052?pt=UK_MusicalInstr_Amplifiers_RL&hash=item51c06b203c
Instant 16-ohm load rated at whatever power you like.
Yes, this is completely serious!
Maths: resistance = voltage-squared/power. 240*240/2000 = 28.8 ohms. That's the 'hot' resistance, and is already in the safe range for a 16-ohm amp; the 'cold' resistance will be a little lower. If in any doubt, just meter it. A 3KW heater might be even closer if you can find one - probably a 3-bar "electric fire".
If it has a switch and you're concerned you may accidentally turn it off (open circuit, bad) either tape it into the on position or go inside it and hardwire across the switch.
I did exactly this when I was bench-testing a couple of Hiwatt 400s a few years ago. I didn't have a proper load anywhere near big enough for the ~445W clean and ~775W fully cranked that these monsters will produce, so I used a fan heater .
Use a volume pedal or similar connected to the other speaker jack to derive a line-level signal.
Someone we know had an empty Hiwatt 4x12" and four spare 200W EVMs at the time as well, so we could have built the world's loudest half stack. I wanted to try it but someone bought the heads.
http://i52.photobucket.com/albums/g24/slate_photos/Mobile Uploads/IMAG0046_zpso2lim4lk.jpg
Cool! How are you finding it?
It's a handy tool to have lying around for that price.
It's built well and it does what it says on the tin, but I'll be returning it.
I brought it for the cab Sims but they're really no different to any of the other hardware cab simulators that I've had (which is not very good at all, IMHO).
May be OK for foh, but for recording it just sound fizzy and flat - especially compared with the excellent IR's that are available these days.
I have a sequis elemental that I use for the load box and DI, so the mesa has nothing else to offer me.
Surprisingly enough, into a PA for live use it barely matters. The H&K Red Box was adequate, and Koneguitarist reckons even his old passive Peavey one is near enough indistinguishable in a gig mix.
