Modded schaller boost pedal - repair.
Part of a job lot of guitar pedals I recently picked up, it's a vintage Schaller booster but it's be modded with two additional wires running from the casing.
I would like to convert it back to stock as far as I can any ideas thanks.
https://ibb.co/Kw5yNv4
  • The non-original cables look like a send/return insert loop. The one remaining screw down terminal looks like it attaches to something chunky and immovable - such as an electronic organ.
    Thanks , found the picture below of a non modded one .  Could I remove the non original wires and reattach a 9v battery Clip , from the pictures it looks like the live wire from the clip would attach to where the brown wires are currently ?
    https://ibb.co/YWfy6Z8
  • FunkfingersFunkfingers Frets: 15261
    edited September 2021
    I stand corrected. What you have on your modified Schaller Booster is an external power supply connection.
    FWIIW, the terminal on the end of one of the non-original cables resembles a connector on one of those organ pedals illustrated in one of your other Discussions.
  • I stand corrected. What you have on your modified Schaller Booster is an external power supply connection.
    Thanks, will connect a 9v clip to the blue and brown wires and hopefully it will work.
  • Just had a chance to remove the non original wires and install a battery clip and it all works as it should.
    Amazing sounding unit has both a treble boost plus a varirone control on the front which allows you to dial in some sub / Synth bass tones.
    Thanks again for the help
    https://ibb.co/vvJ7tD9
