Another simple host, with few bells and fewer whistles, that just works ...
From Windows/OSX devices and iPad, via a browser
- Login to your account at imgbb.com
- You can either select the image from the "My Profile" option (drop down under your Avatar) or the "Albums" option, depending on how you've set-up your storage.
- If the former, then as you hover your mouse* over an image, a column of 5 options appears in the top right of the image.
- The second option is "Embed codes" - select that.
- A pop-up window appears. There's another drop down list box - click that and select "Direct Links"
- Copy the text that then appears in the box beneath the drop down list.
- Back to the forum, and "paste" the copied link into the attach image/file pop-up.
* if using an iPad, just press & hold until the column of options appears.
From iPad, via appNot found an app to use - but the browser process is simple.
From Android, via appNot found an app to use.
