They both have DI outputs. They are both mentally loud with the right cab.
They both have clean / drive blends and all that good stuff.
V2 has a different EQ system with a graphic rather than rotary controls. No real advantage either way, good sounds in both.
The V2 also has a built in compressor and has an IR loader so the IR's appear on the DI and the headphone out (not on the speaker outs of course) which can be great for a FOH signal or recording.
V2 also has some very limited midi control in regard to triggering the drive channel with other gear.
is the 900 overkill? Would the 500 models be more than sufficient for gigs?
I've seen a few failures of the 500 for some reason but none for the 900.
And headroom is always good to have.
