see the other thread, regarding computer specs,
"I did loads of multitracking with Reaper on a Dell Latitude Core 2 duo with 2Gb ram. But it was optimised for audio in terms of good drivers for my interface and nothing unnecessary like Office fast find . iTunes updater, MS one drive etc running in the background."
You will probably be fine with drums, bass and guitars. If you and loads of other stuff and max out the plugins it will probably get sluggish
You can repeat that for as many tracks as you like and then consider bouncing a few tracks into another one, to cut down the processing load.
There are some VSTs that are v heavy on CPU. Anything adaptive (such as a dynamic EQ or limiter) can be demanding.
Having said all that, it could well be OK.
