A near mint condition example of an uncommon Les Paul. This is the 2015 wide nut version, at 45 instead of 43mm, giving much better playability. This model originally came with the temperamental G-Force tuner, which has been replaced with a set of high quality manual tuners.
The original spec from Gibson is below. The build quality and finish is excellent with no marks or damage to note. Comes with a padded case.
This is a reluctant sale of a lovely guitar, but I'm a bass player at heart and cant justify having this hanging on the wall unplayed.
Can deliver at fuel cost within a reasonable distance. Just ask!
- Zero Fret Adjustable Nut (patent applied for): Added action adjustment
- P–90 Dogear Alnico Slug Pickup: Brighter Tone with a more percussive attack
- Wider neck and fingerboard: Increased playing area with same string spacing
- Comprehensive wood selection and grading: Rarest and finest materials for best instruments
- Thicker Rosewood Fingerboard: Increased mass for sustain
- Pearl Inlays: Better appearance and value
- Smoother sanded, buffed and oiled fingerboard: Improved playability and feel
- Comprehensive Setup (Lower Frets, Improved Plek, Intonation): Silky smooth action and bending, improved intonation
Improved contact output jack: Secure contact and uninterrupted signal
- More robust cables: Stronger signal strength
- Les Paul 100th birthday signature: Honouring a genius with a facsimile of his actual signature taken from a pickguard autographed by Les
- Les Paul Hologram: Authenticity and tribute
