I'm looking for a wee nagging doubt to be eased re: a Roman numeral label of a borrowed chord
close2uclose2u Frets: 997
edited October 2021 in Theory
Hi all.
Just a quick ask for some assistance / assurance on Roman numeral notation in a specific context please.
I've been asked by a friend to help label his chord sequence in the key of G minor with some chords borrowed from the parallel G major. And for all I'm fairly sure, there's something about the look of one of the chords that is nagging at me.
The progression starts diatonically:
| Gm  | Eb  | Bb  |  F   | Gm  | Cm  | Dm  | Gm  |
|    i    |  VI  |  III   | VII |    i    |   iv   |   v    |    i    |
Then repeats with some borrowing in bars 2 and 7:
| Gm  | Em  | Bb  |  F   | Gm  | Cm  | Am  | Gm  |
|    i    |  #vi  |  III   | VII |    i    |   iv   |   ii    |    i    |
It is the Em that I don't feel at ease with. I'm fairly sure it does take the label #vi.
Its root is the minor's 6th note of Eb raised a semitone.
But ... a little doubt exists.
Am I just getting this uneasy feeling because it is not so common for minor chords to be borrowed when composing in a minor key? Which makes it simply unfamiliar rather than incorrect.
  • BradBrad Frets: 658
    I agree #vi does look a little strange, even if I think it does make sense.
    As the chords are borrowed from the parallel major, you could perhaps label it as vi/I? So I’d interpret that as the six of the major one chord. Ditto the Am - ii/I because the ii of Gm is Am7b5.
    |    i    |  vi/I  |  III   | VII |    i    |   iv   |   ii/I   |    i    |
    Another, perhaps more complicated way, could be to label it as the preceding ii of a secondary dominant that isn’t there. As Em is also the ii of D, whose V is A7. So it’s a stretch… but ii/V?
    |    i    |  ii/V  |  III   | VII |    i    |   iv   |   ii    |    i    |
    D is the V of G, so as Em is the ii we’d call it two of five. You could insert an A7, so Em7 - A7 - Bb would give:
    | Gm  | Em  (A7) | Bb  |
    |    i    |  ii/V (V/V)|  III   |
    To be honest, I’ve pickled my own head there with that last one :wink:
  • vizviz Frets: 10681
    edited October 2021
    | Gm  | Em  (A7) | Bb  |
    To be honest, I’ve pickled my own head there with that last one wink
    It’d be the V/ii not the ii/V, coz it’s the 5 of the 2, not the 2 of the 5
    But, yep, I think #vi is the proper one, functionally speaking anyway. Like if it were in G major and the chord were Eb instead of Em, that’d be bVI instead of vi.
  • JalapenoJalapeno Frets: 6385
    Might be easier for the particle physics calculations to think of Gm being closer to Bb Major, than G Major - Eb is then a bog standard IV chord
    Gm is the natural minor Vi of Bb Major, with all the Gm notes in the BbMaj scale
    Feedback
  • close2uclose2u Frets: 997
    Thanks Brad. I'm glad it's not just me that has to do a double take yet thinks it is correct. :)
    viz said: ... I think #vi is the proper one, functionally speaking anyway. Like if it were in G major and the chord were Eb instead of Em, that’d be bVI instead of vi.
    Thanks viz.
    I'm very comfortable labelling major and minor chords coming in to a major key from a parallel minor including flats.
    I think it is just the lack of familiarity of borrowing minor chords in to a minor key progression where the sharp is required.
    Jalapeno said:
    Might be easier ... to think of Gm being closer to Bb Major ... Eb is then a bog standard IV chord
    Thanks Jalapeno. It is not the label for Eb that is the issue. It is the Em borrowed from the parallel G major key.
    If the progression were considered as in the key of Bb major rather than G minor, the borrowed Em chord would still require a sharp symbol, but would be a #iv rather than a #vi.
    Thanks all.
    I'm happy to go with #vi and advise my friend of that.
    edited October 2021
    Thanks viz.
    Yep, it’s not very common in minor, and that’s the only sharpened possibility, apart from the #iii which is pretty much not going to happen, and the #vii(dim) which is an inversion of the V (which is itself often borrowed from major)
    In general, borrowing seems to happen more often with major pieces.
    One of the more common borrowings in a minor key is the ii-V-i, where as well as the V, the ii is often borrowed, not from major but from the dorian mode. By rights it should be ii(dim)-V-i, but you often hear it played as a standard ii to lighten the mood a tad and make it not sound so tragic and classical.
    | Gm  | Em  (A7) | Bb  |
    Haha indeed, I can see where you’re coming from there and it’s another option :smile: however…
    If memory serves, I was always taught that any non diatonic minor chord should be viewed as a ii because of the high likelihood of it moving to it’s V. As I said, it’s a stretch :wink:
