For the first time in a while ive been without a guitar for weeks as it had to be sold to fund towards a car replacement. so needing a cheap guitar to get me by and also a excuse to learn along the way, in which I will be asking many questions to the more knowable members.
Onto the guitar. I have a telecaster body which I believe is ash and weight a tonne and a maple neck which says Harley Benton on the headstock, I can only presume the body is also, a friend used it to practice removing all the thick poly finish in which he did a shite job and the wood I covered in burn marks and deep grooves scraped into it.
the neck looks decent and straight but need to sort all the frets and nut
The electronics have all been crudely removed at some point so will be replaced.
hardware feels more like chrome covered plastic and feels cheap, soft and very brittle so will be replaced at also.
il get pictures up tomorrow but maily at this point coming up with a plan, advice and pricing it up.
so far the basics are new everything, try make the neck playable and thinking re route it with a humbucker in the bridge and keep single coil in the neck and a switch to split it down,
A humbucker rout will still not fully cover the old tele single coil rout but it should be hidden under the new bridge but I'd check that if I were you.
http://www.axetec.co.uk/guitar_parts_uk_039.htm (bottom one).
I’m looking for something with just the bridge bit with six saddles as it makes more sense than the 3 saddles currently and thinking about a way about mounting the bridge humbucker, end of the day the guitar is ugly so don’t need anything to fancy or nice
