If you interrupt the "collector" wire between the two poles of the selector switch, it is possible to direct the signal from each pickup to the appropriate half of a dual-ganged 250/500k stacked pot.
The signals are combined by linking the centre terminals of the ganged pots.
I’ve been pondering the same question…Paul in the link above has done a great job of demonstrating
Either that or use 500K pots and simply add a 470K resistor to the bridge pickup so it sees a roughly 250K load.
if you can’t handle my monosyllabic voice on the video …this diagram will do
https://sixstringsupplies.co.uk/pages/hs-telecaster-wiring-diagram
Our YouTube Channel for handy "How-To" Wiring Tutorials
does the above wiring apply to a tele with a P90 in the neck?
