My recently acquired Telecaster partscaster has a lovely Allparts fat neck, which I like, but the previous owner had it refretted with 6105’s, which I’m having a bit of a problem with.
They’re fine when I’m playing anywhere below the third fret, but some cowboy chords play horribly sharp, especially the b & g strings.
I know it’s because I’m using a death grip on the neck and someone will tell me to adjust my technique and I’m trying to do that, but meanwhile I’d like to find a way of mitigating the issue.
I’m using 10’s and they’re just right for me on a Tele, though I’d be willing to try 11’s, but apart from that, has anyone here ever tried using a compensated nut? I’ve heard that Earvana compensated nuts can help with this, but I’ve also heard they can introduce different issues themselves.
Waddayathink?
Instagram
Bandcamp
You google it and most discussions on other forums are clogged with people offering opinions on why it shouldn’t/doesn’t do what it claims to do and in fact does the opposite of what it claims.
I’ll be interested to hear some feedback about that when you get it back.
I checked the the other strings and my guitar closely corresponded to the chart about Earvana nuts on the FelineGuitars website. After the installation of the shelf nut, it took me a day or two to mentally accept the more accurate notes played. And they are more accurate than before as my Peterson StroboStomp clearly shows.
I checked my other guitars, my CS Strat is a hair sharp on the G note low E string whereas my Tele is over 1 cent sharp when fretting the same note. To my ears, 1 cent sharp is noticeable, YMMV. The Tele will probably be upgraded next with an Earvana nut.
I noticed no change in the sustain and cosmetically little difference on my Epi. Chords and single notes sound much more in tune. My Anderson has BFTS and chords and notes sound absolutely in tune on that guitar. The Earvana nut is not quite as accurate as the BFTS but it is very close, easy to fit and totally reversible if you don't like it. A good guitar tech can make a standard nut work (as on my Strat) so nut replacement is not the only way to achieve chords and notes playing in tune, but it is an easy way to attain this goal.
To finish, if you want your guitar to play in tune, an Earvana nut is the easiest way to achieve this. Go for it.
Nil Satis Nisi Optimum
I've got a feiten on the Suhr too ... on my tele - I'm just coming up with a tuning that gives me areas of the neck I trust and I'll adopt scales for that
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
