FS: Cornell Traveller 5 Hand Wired Amp
I’ve had this a couple of years now and it’s seldom used. But something has cropped up guitar wise that I can only fund by selling something. I don’t want to sell my new Feline DC so this one is up first.
The photo album.
https://www.flickr.com/gp/182610640@N08/d8LnBMA video review
https://m.youtube.com/watch?v=X4agBXo377U
£699 new - how does £380 sound for it.
Blurb:
The Traveller is a 5-Watt tube amp based around a single ECC83 preamp and EL84 power amp valve. The amp has four output settings: 0.05, 0.25, 1.5 and 5 Watts. It’s fitted with a single 8″ Celestion speaker mounted into a solid cabinet finished in black Tolex with a basket weave speaker grill.
Overview
- - Traveller Five 5 watt combo Specification.
- - 5 watts RMS with Cornell 4 way attenuation.
- - Hi and Low Inputs.
- - 8 inch Celestion speaker.
- - 12AX7 pre-amp valve and EL84 output valve.
- - Clean and Mean switch.
- - Gain Tone and volume.
- - Extension cabinet output.
Specifications
- - The Cornell Traveller 5 is powered by 1 x ECC83 and 1 x EL84. The amp also has 4 power settings A - 5 watts B - 1.5 watts C - 0.25 watt D - 0.05 watt
- - Traveler 5 refers to the maximum output of this fine amplifier in Watts. Ranging from clean to amazing high gain all controlled from the volume knob on your guitar.
- - 5 watts RMS with Cornell 4 way attenuation. Hi and Low Inputs. 8 inch Celestion speaker. 12AX7 pre-amp valve and EL84 output valve. Clean and Mean switch. Gain Tone and volume. Extension cabinet output.
Don’t be fooled by the 5W rating this isn’t ‘that’ quiet even on the 0.05W setting, but it’s more manageable.
I’ll deliver this locally free, and possibly further afield for a small fuel contribution..
Thanks
Steve
Previously known as stevebrum
Got the pics sorted yesterday.
Would £380 be more tempting?
Cheers
1980 Tokai LS-80
The traveller is somewhat wasted on me you might say…
https://guitar.com/review/amplifier/cornell-amps-traveller-5/
I’ve had pleasing sounds out of it but as mentioned above with life,kids, neighbours I don’t plug in that often.
https://www.thefretboard.co.uk/discussion/217907/fs-feline-dc-jr-tv-yellow-1200
