What is best for a squeaky Wah pedal ? Lithium Grease or Silicon
hollywoodroxhollywoodrox Frets: 4131
Hi I have a Slash wah pedal I bought earlier in the year with an unexpected windfall
  It’s so much better sounding than the old GCB95 I used to have .
  Trouble is it has an annoying squeak . It may be coming from the plastic belt or the pivot point
   Wonder if lithium or silicon is best . Didn’t want to use oil based stuff like wd40 owing to its propensity to rot certain plastics / rubber etc
im hoping it’s the belt mostly as o don’t fancy taking it to bits as it looks like the pivot is riveted when I’ve looked online . Not sure really
thanks
  • maharg101maharg101 Frets: 684
    This one goes to eleven
    Trading feedback here
  • ecc83ecc83 Frets: 1630
    Never in over 50 years have I ever heard of WD-40 'rotting' anything! Anyway, you can get greases in aerosol cans and Lithium, Graphite or Moly will all work as well as silicone. Do not BTW ever use silicone lube on metal to metal mechanisms.
    Dave.
  • SassafrasSassafras Frets: 30289
    Haven't tried it myself but apparently castor oil doesn't rot rubber or plastics.
    Dave.
    Why's that Dave?
  • EskerEsker Frets: 80
    I agree with Dave, WD40……actually I just replaced the pot on my wahcko
  • hollywoodroxhollywoodrox Frets: 4131
    edited October 2021
    I thought petroleum based products rot rubber !
    I used to use silicon on my metal detector gasket .
  • Thanks yes I may go with one of them then I only need a small amount
