Edit: you did ask for obvious
Trading feedback here
no suggestion too obvious
Just checked the highest ones and they’re fine. Would need to move furniture to check the downstairs ones but as it was working fine earlier I don’t think it’s that. But thanks for the thought.
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
Check the zone valve(s) first if it's a conventional system ......they can stick but you can often push them over manually if you already have a cylinder of hot water.........check pipe to valve.......if no joy
as exocet says .......the central heating pump may have stuck while not in use (that where all the shit in the system sits and corrodes the impellors )
Boiler water pressure in a combi system or lack of will have cut the thermostatic cut-out off ages ago and you wouldn't have hot water so it's not that and it wont be an airlock either
pump or Zone valve failing that programmer failure but you can check with override
The timer connects to the valves and the valves connect to the boiler via a junction box.
The valve(s) normally have a silver metal cover where the wiring goes in. It's actually the valve that switches the boiler on - the timer drives the valve actuator - if it's working, it opens the valve and closes another set of switch contacts that causes boiler to fire. However, if the actuator (or solonoid) has failed (they do), the boiler won't fire up. As you have hot water, I'd say that you will have 2 valves (one for Hot Water and one for Radiators)....or...
If its an older gravity fed system, there are no powered valves. The timer fires the boiler which heats water. Hot water rises causing circulation in the heating coil contained in hot water tank that is normally located in the room directly above the boiler. It's common for a bathroom radiator to be included in same circuit. For heating, the timer fires the boiler AND turns the pump on to feed the radiators.
With this sort of system, you can have Hot Water OR Heating and Hot Water. You can't have heating without Hot Water. Pump failures are very common because for 6 months of the year, the pump is sitting in sludgy water without turning because the heating is not used. Come winter, the pump has ceased up and radiators fail to warm up.
Not sure where I should be looking for the valves?
There are two fat pipes that come out of the bottom and then loop behind to disappear upstairs. This would suggest 2 valves I think?
