FS : One Control White Loop A/B Dual True Bypass Loop
Dual true bypass loop pedal allowing pedals to be placed in two seperate loops. Switch between the two loops or bypass completely.
The unit can also be used to switch amp channels although I'm not certain if it's compatible with all amplifiers.
Also has 2 9v outlets to power pedals - to use this you must also power the pedal itself which in turns powers the LEDs.
Great little pedal, now surplus to requirements as I'm slimming down my setup.
Velcro on the bottom and includes original box
£60 inc P&P (RM 1st Class Recorded)
