In the continuing saga trying to get my Bass 12 working properly, I need the correct schematic. The only ones available are the Bass 12 and the Lead 12, which are hand drawn and look like they have been scanned using an old 1970's school Banda machine (you'll need to be of a certain age to know what they are)!
So far I have imported jpegs of the board (both top & bottom) into powerpoint, then traced over the PCB and superimposed the component symbols on this. Unfortunately there are limitations doing it this way. If I want to move any of the components around, the connecting node points don't move. Enter this rather stupendous piece of software:
I stumbled across this and it seems that this might be the answer. My current thinking is to add all the components, then when I start connecting them together I'll delete the pathway off my powerpoint so that I can keep track of what is connected where. Hopefully this will give me a circuit that is all joined up so I can move things around to come up with a more accurate schematic. As a starter for 10 I may lay the components out in the same approximate positions as the Lead 12 schematic, start connecting them and see where it goes from there. If I can reverse engineer the schematic, at least I'll have a solid foundation to move forward. At the moment I'm stumbling around in the dark, although the help and advise that I have got from you guys and in particular
@icbm, has been a maglite illuminating the way!
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
https://bancika.github.io/diy-layout-creator/
Out Principal Technician used to nick cans of it to top up his car.
Stripped the paint off where it dripped on the outside & he eventually burned a hole in his pistons. Oh how we laughed...
