BASS AMP - Heavily upgraded Fender with Eminence Speaker! BOOM SHAKE THE ROOM (or something)
Hi folks,
I've always been a massive fan of the Fender Rumble amps - however a change from the standard 15" to an Eminence Basslite Neo has made a cracking amp simply phenomenal. The output is huge and the clarity is something else. I can't rate this setup enough, it sounds simply awesome and is very giggable thanks to the efficiency of the Basslite - the added clarity means less need to crank it too!
Collection much preferred from Ledbury in Herefordshire or Brockworth in Gloucestershire.
Don't miss out, this is basically being sold for a little more than the cost of the speaker alone! JUST £125 - bargain!
Cheers,
James
