Valuing an Overwater bass?
imalrightjackimalrightjack Frets: 3745
edited December 2021 in Bass
Hi all,
I just took this wonderful bass in trade but I’m a little unsure on value. I might keep it but curious to know what it’s worth, as trading or selling to buy a lesser model might make more sense, as I don’t often play bass.
It’s the equivalent of a Classic J4 from mid-2000, immaculate with original Hiscox/Overwater case, but with Fender CS Classic 60s pickups and a John East J-Retro 01 Deluxe pre-amp system.
It was made for Mark Hodgson and was apparently used on sessions with Amy Winehouse, etc.
Any ideas welcome.
Thanks!
10-BCE9-C9-CA9-B-4-EF0-8-B93-16-A32-FF5-C455 0-DBD99-E2-042-F-401-B-A914-2-BD91-AA03896 D81-E7-EFA-F09-B-48-CD-8-DD5-6-DF1-E069-BC31 ED789-A96-A939-40-F6-9996-87796683-CCCB B26-B0-B78-BB2-D-4734-B4-DD-E6-EBE271-F855 6-C7-C8-C5-B-3179-426-B-88-B3-4-FDC93-A9-F37-B E73-A8464-0-DC9-4947-8-C37-DA7-EF142730-C 8-B006-E24-C1-C7-4457-8-A56-F7282004-A670 3-F284-A15-455-D-4099-9-EA6-6-B4-C76-A23202
Trading feedback info here
My band, Red For Dissent
  • Rowby1Rowby1 Frets: 1279
    I don’t know about value but the bass player in one of my bands has a sea foam green version of the same bass (not sure on the spec of the electrics on his though) and it sounds fabulous!
    Edit: his is a five string.
    So, not a helpful post from me, sorry OP
    @Rowby1 This is a beast - I just don't think I can justify keeping it!
    The problem with Overwater is (like most custom builders) - they can be expensive to commission from new but lose a lot of value on the used market.
    I've seen similar spec J's go on Basschat for £1000 - £2000 and it will totally depend on whether someone is looking for one. The CS 60's pickups are great, and the John East J-Retro is one of the best preamps out there (IMHO). I'd start at the higher end of this range and work from there.
  • The problem with Overwater is (like most custom builders) - they can be expensive to commission from new but lose a lot of value on the used market.
    Thanks, @Bridgehouse ;
  • ICBMICBM Frets: 72313
    Not my thing unfortunately, but it's so nice to see a modern but quite retro-looking instrument that isn't another 'relic'.
    I would agree with Bridgehouse - it's difficult to be more accurate.
    Have you tried listing on Basschat as well? Most of the likely purchasers will reside there…
  • Have you tried listing on Basschat as well? Most of the likely purchasers will reside there…
    Thanks, @Bridgehouse Listed at £2k. We shall see! Thanks again.
    GLWTS!
  • Cheers!
