The K29 is a 30(ish) watt non-MV amp in the Trainwreck Liverpool tradition
It’s hand-built without compromise, using top-notch components
It runs a quad of EL84 and 2 ECC83s in the Pre-amp
Tonally, it’s from the Marshall/Vox family end of things and is one of the most dynamic amps available – genuine clean-to-mean with your picking dynamics and breakup that’s wonderfully progressive and harmonically rich as you dig in
If you want to hear how versatile, dynamic and great sounding it is, pls check out Simon Gotthelf’s demos on YouTube:
See the Komet site for full specs: http://www.kometamps.com/products/amplifiers/komet-29
It's a phenomenal amp - if you want to get very close to a real original Trainwreck in terms of tone and feel and don't have £50k to spend on one, it might be worth a look?
IF you can get one (hint, you can't due to supply problems impacting amp building in the US, so don't believe Bax Shop BS, saying they can get you one in 10d!) then you'd be looking at around £3.5k new
..and tone wise, dynamics etc, it's in that category
Weights 13kg and fits a medium lunchbox sized flight case
