Help with wiring please
FlipFlip Frets: 68
edited December 2021 in Making & Modding
I wonder if some kind person can help me with a small wiring problem. I attach a photo of the loom I've extracted from a 3/4 size Chiese strat copy I bought for my grandson. When I got inside I found the circuit fairly wrecked. The loom consists of a single neck pup, a 'double' bridge pup, a 5-way selector switch and a tone and vol pot. The tone pot is all but destroyed.
A group of wires comes from the 'double pup which I take to be a humbucker that can be switched via the 5-way switch to a single coil. Of the wires leading from this pup the black is soldered to contact 1 of the 5-way switch, the red to no 2, the green and the braid to the grounded pot case while the white is unsoldered.
Could someone kindly suggest to what I should solder this white wire?
Many thanks
Flip
