Well it’s been far too long since I got involved properly in one of these. I have a long list of unfinished (and unstarted!) projects, so let’s add one more to it!
My challenge is pretty straightforwards, I’m going to build a mini-head cabinet to transplant my Marshall Reverb 12 chassis into. The stock combo comes with an internal 8” speaker which hampers the tone, plugging the same amp straight into my G12H creamback-loaded Zilla sounds superbly JCM800-esque and at very usable home volumes, so that’s the way this one will be left!
I’ll see what timbers I can get locally, as a solid cab with a stain/oil finish could be interesting, otherwise I’ll go for simple tolex ply construction in traditional Marshall fashion.
My stretch goal will be to replace the faceplates with silver/brushed alu ones and turn it into a Jubilee-esque mini-head.
*edit* Current state:
Assumptions:
- A head cab is theoretically less susceptible to vibration than a combo/speaker cab, so I could get away with reinforced box joints if I wanted to - particularly on a tolexed cab. However, I'll likely finger-joint it instead.
- Head cab will use ¾" thick materials.
- Dimensions and plans will follow that of the original combo, albeit reduced in height.
Materials:- ¾" ply / walnut, oak, maple, or wenge (I can get the hardwoods easily enough from a local flooring company)
- Silver tolex + adhesive
- White piping
- Fixings
- Mesh grille (rear)
- Custom faceplates x2
- Corners x4
- Handle
- Feet x4
- Beers
Tools:What've I missed?
Heat gun can help for the tolex
I'm also not sure what ohms the 8" speaker was in my 5205 combo, and probably should have checked that before plugging into my Zilla 1x12!
I've started actually reading the NEETs course as well so that I can begin to understand something about electronics and try to work out what component does what to the signal path.
The 5205 is 16 ohm, I think even in the 8" version. If your Zilla is 8 ohm, be thankful that Marshall overbuilt the amp .
It doesn’t sound particularly dark btw, just needs a but more presence at lower volumes. When it’s cooking a little it sounds superb!
