Barely used - purchased in 2020 from John Lewis. Comes with original cartridge. Really great turntable - automatic and belt driven. Sounds great and takes both MM and MC cartridges - so super versatile.
Original description:
Advanced Fully-Automatic Belt-Drive Turntable
A revolution in automation, the LP3 blends outstanding analogue sound with advanced features unique to a fully-automatic belt-drive turntable. Play 33⅓ & 45 RPM records with a pre-mounted AT91R Dual Moving Magnet phono cartridge whilst the tonearm’s removable universal headshell and switchable cartridge mode allows listeners to experiment with moving magnet and moving coil cartridges. Complete with a built-in phono pre-amplifier, the LP3 represents the next level for vinyl lovers.
Fully automatic belt-drive turntable operation with two speeds: 33-1/3, 45 RPM
Balanced straight tonearm with hydraulically damped lift control and lockable rest
Built-in switchable phono/line pre-amplifier with attached dual RCA output cable
Switchable modes for moving magnet and moving coil cartridges
AT91R Dual Moving Magnet™ phono cartridge and AT-HS3 universal headshell
Anti-resonance, die-cast aluminium platter with 4.5 mm thick rubber mat
Damped base construction for reduced low-frequency feedback colouration
Mm / Mc Cartridge Selector Switch
Switchable MM/MC mode allows the listener to use both Moving Magnet and Moving Coil cartridges on their LP3, allowing for greater sonic customisation – a unique feature not found on most turntables with a built-in phono preamplifier.
AT91R Dual Moving Magnet Cartridge
Specially designed for the LP3, the AT91R Dual Moving Magnet™ phono cartridge incorporates an aluminium cantilever for higher-rigidity and improved pick-up of subtle details.
Universal Headshell
Removable universal AT-HS3 headshell allows users to upgrade their cartridge to further enhance their sound. Suitable for 1/2" mount cartridges and 4-pin turntable arms.
Balanced Tonearm
Incorporating a hydraulically damped lift control and lockable rest, the LP3’s straight balanced tonearm includes a radial ball bearing for horizontal movement and pivot bearings vertical movement.
4.5mm Platter Mat
Reducing unwanted vibration and for stable play, the LP3 includes a 4.5mm thick rubber platter mat.
