Hi chaps
I want to get into doing some recording of music. I started having a fiddle with Reaper pre-pandemic, but then everything got turned upside down and it wasn't really practical at home any more.
My home laptop is shared by the Mrs and so I want to buy something cheap that'll do the job otherwise it becomes a problem with both wanting to use the only laptop at the same time. I was thinking about getting a Chrome Book as you can get them for under £200.
Does anyone have any experience with using Reaper on Chrome Books?
If this is a stupid idea, are there any easier to use DAW programmes that will work on a Chrome Book? Otherwise, I'd go and by another windows laptop, but don't really want to spend a wad ...
Any advice appreciated. :-)
I don't think any decent recording stuff runs on a Chrome
Hop Pole studio did a couple of vids on Reaper on a RPi, worth a look.
As was suggested, get the Chromebook for the wife (assuming she's only using the laptop for browsing), and reclaim the laptop. It's by far the simplest approach.
Chrome books are complete junk electronically, awful failure rate, normally from the USB C handshake chip which writes the board off.
Your best option is whatever windows box you can afford.
Reaper tends to be less resource hungry than some other, more flashy DAWs, particularly if you use the stock VSTs where possible.
I you have a spare TV, you will be able to run Reaper ARM version no problem.
As @digitalscream says, Linux is a different world, but the Raspberry people seem to be making it more accessible to all, and if you are only dabbling in recording there will always be something new to discover, why not make a new OS something else?
A cheap interface and mic is all that needs adding to this setup, or you could go down the never ending road of commercial VSTs and hardware / software, I would say a decent entry point would be a second hand MBP for £400 and up, with Logic, £150 last time I looked. I chose something similar around 5 years ago and the machine is still working well. Maybe I got lucky, but once you start doing it, there will always be things you 'need'.
