After a buzzy gig (singles coils plus loud on-stage volume plus overdrive pedals), I am getting a noise reduction pedal.
It'll be either the Boss NS2 or the very similar but much cheaper Behringer version, both with send and return as well as in/ out.
So, my understanding is that the pedal ideally wants to go after the gainy stuff, where it will reduce the unwanted noise they generate, but before things like reverb/ delay, so as not to unpleasantly chop off the end of reverb tails etc.
Easy so far, if you have all your pedals in one chain. But I put my time/ modulation pedals into my FX loop, with the gainy stuff straight into the front end, as I believe those people who, unlike me, actually know what they are talking about call it.
So, where does the noise gate pedal go in such a set up? Or should I use the send/ return loop that the pedal itself offers? If so, why? What does that even do?
Advice is much appreciated!
now, if only the Amazon dude hadn’t lost my noise gate pedal in transit….darn it.
HI all. After the gain. If you're using pedals for gain you can stick them in the loop of the pedal - if it has one. If not, put in the amp FX loop. If you use reverb / delay, put the gate *before* them as the gate will cut off some of those nice repeats / trails.
BTW - if you're interested I have a TC Sentry going spare that has a built-in loop. It's a pretty good gate. PM me if so.
Truth. This is a why I have the Sentry going spare. I sorted my issue with power and shielding the inside of my strat. If you play super-hi-gain type stuff you may still need a gate though.
soundcloud.com/thecolourbox-1
