I have only ever owned two "P90"-equipped guitars. One was the LP Junior type with single dog-ear P90 and the other was a double cut LP Special type with two soapbar P90s. Neither of them were Gibsons, but they were what I thought of as good quality copies. Obviously neither of them had Gibson P90 pickups in them, so my experience of what "the real P90 sound" is probably quite limited. I do know that the physical dimensions of the coil and the magnet placement have a large bearing on why a P90 sounds different from a standard fender style single coil and a humbucker.
Because I spent so many years playing Fender type guitars and only had one Gibson type guitar during those years i haven't really thought at all about P90s. I did, however, buy a few Gibson type guitars fairly recently and have wondered about the P90 sound.
Each time I am buying parts from AxeTec I see their "Alchemist" pickup
that they say gives "the classic P90 sound in a humbucker format", and I wonder whether they really do sound anything like a P90. I am toying with the idea of testing one of my LP copy guitars with these drop-in replacements, and even if they give a semblance of a P90 sound it would give me a different guitar. One thing I am certain of is that I do not have enough disposable income to start buying expensive pickups, and even a pseudo-P90 sound would be enough of a change between single coils and humbuckers.
Has anybody tried out these particular pickups or any of the more budget-conscious pickups of this type and do they sound close enough to a P90 to qualify as being quite different from an ordinary single coil?
I have also had experience with Alegrees and Seymour Duncan Phat Cats in the humbucker sized format and have Gibson P90s in a Les Paul Special. None of the covered ones sound exactly like a P90 (Oil City doesn’t offered covered ones for this reason) but for me the Toneriders are in the ballpark and sound great in their own way. In that price range I prefer them to IronGear
Seymour Duncan has their P-Rails pickups. These make a decent stab at both humbucker and P90 tones (plus two less successful others).
Alegree Chameleon humbuckers are intended to be similarly versatile. Probably best to PM the man himself for a proper explanation.
IronGear Alchemist Alnico II humbucker sized P90 (metal cover) £67 a pair:
Bridge: 7.6 kOhm
Neck: 5.3 kOhm
Alegree Sea Smoke Alnico II humbucker sized P90 (metal cover) £120 a pair:
Bridge: 8 kOhm
Neck: 7.5 kOhm
Oil City Mighty Ninety Alnico V uncovered humbucker sized P90 £175 a pair:
Bridge: 8 kOhm
Neck: 7.5 kOhm
Seymour Duncan Phat Cat Alnico II humbucker sized P90 (metal cover) Over £180 a pair:
Bridge: 8.5 kOhm
Neck: 8 kOhm
Tonerider Rebel 90 Alnico II humbucker sized P90 (metal cover) £90 a pair:
Bridge: 9.3 kOhm
Neck: 8.4k kOhm
Alegree Desert Dew Alnico V humbucker sized P90 (metal cover) £110 a pair:
Bridge: 10.5 kOhm
Neck: 8.3 kOhm
Only have experience of Phat Cats. They are great but also really pricey. Not precisely the same tone as my P90s but that could be case they are on a Tele with a Tele bridge set-up. This guitar records wonderfully. Details here.
https://www.thefretboard.co.uk/discussion/149667/ngd-black-double-bound-custom-telecaster-with-p90s-custom-build/p1
