I have been thinking to redo the top of my Yamaha Pacifica , but i have always thought , that it'd be better left alone as it was a birthday present from my wife .
Unlike my wife
this one got some beating to it and some heavy gauges here and there .
I was thinking to get some wicked top I like, drop it on top and finish it the way feel is cool .
So the question is , is it easy enough to add veneer ( after skimming the top off ) to top of the guitar ?
How do you go about to cut out all slots ,pockets and holes once a veneer is glued in ?
E.g. https://thefretboard.co.uk/discussion/94502/finished-pics-a-quick-lighten-and-veneer-job#latest
As you said, leave it alone & enjoy it for what it is & all the memories you have.
If you fancy trying it, do it on something without sentimental value first, even if its just a scrap £40 body you don't use for an actual build.
Instagram
Like a lot of things, while it's actually not overly difficult - and needn't need a lot of equipment - it does, nevertheless, require a number of learned skills. And learning skills are best not done on something that matters.
Best thing would be to pick up a wreck on ebay and try that out first.
Ref @BillDL 's question:
There are a number of different ways of veneering, but the two most popular methods are using a vacuum bag or ironing it on.
I personally use the iron-on technique. I've done a few threads where I go into a bit of detail of how I go about it - I'll see if I can find one - but basically: you use a decent quality PVA wood glue (I favour the Evo-stick green bottled wood glue found in most DIY stores) and coat both the guitar body and veneer separately; let it fully dry; position it; take a hot iron and iron the veneer to the body. The heat melts the two layer of glue into one, the iron flattens the veneer while it's heating it, and when the iron is lifted, the glue solidifies again and the bond is complete. There are tips, tricks and techniques involved, of course.
With the vacuum bag approach, you apply the glue wet, position the veneer and body in the bag, apply the vacuum and leave it evacuated until the glue has cured. Standard wood glues can be used and there are specialist veneer glues available too.
...and if you do, go for a fully finished one, not an unfinished kit body. The reason is that one of the critical, and often most difficult, things is actually getting the finish fully off.
And especially, but not exclusively, Yamahas. You scrape off the top coloured surface pretty easily and think 'well, that wasn't so bad'. But what you take to be the wood underneath is often not wood at all, but a clear coat of one of the hardest substances known to man. And getting that off can break the will of the strongest of us!
I've found the thread but it is so old that the photo links no longer work. I'll see if I can find the original photos and copy and paste the text.
Yes - the melt and stick is repeatable, too. So - as long as there is sufficient glue there - if you find an area lifted, you can re-iron.
Given all the details , I can see clearly that it is not easy at all , and requires a lot of practice beforehand .
I might need to give up on this idea and perhaps buy a wreck one like suggested and experiment for a while on it untill I know i could pull this off without risking loosing the valuable guitar .
Wait the 20 or so minutes until both veneer and body are touch dry then position the veneer on and get the pre-heated iron out.
THIRD TIP: to help the glue to grab while it's cooling, it's sometimes helpful to heat it up, then remove the iron and press down firmly with a duster or clean rag
FIFTH TIP: use the body itself as the template, pierce the veneer overlap with the blade and rest the blade (at the required angle) on the body so the body stops the blade digging in:
It is important that the edges are smoothly feathered into the body wood and that ALL the PVA at the edges is removed from the body wood - otherwise the PVA will show up white as soon as any stain or finish is put on.
The easiest way is to take a sanding block and sand around the complete edge in this direction:
The same goes for the veneer surface as well - make sure that any squeeze through of the PVA through the veneer voids is also sanded.
And that's basically it. The guitar shown on the bulk of the photos above was stained and varnished and ended up looking like this:
So that's basically the technique. There is quite a bit of learning of the skills using test pieces and trial and error (which is why you are wise, @Jazzthat to try it out with a wreck before anything that matters), and there are numerous variations, such as bookmatching, where other techniques and tips are important, but the above probably covers the basics.
Bear also in mind that any mod like this - however much it improves the look - will most likely lower the resale value against an unmodded (even when bashed about) original.
I will have a good read later on and see if I still want to go ahead at some point .
Thanks for you time to showing it .
