I have had the most success at home volumes with the little DSP desktop amps, but again I'm sure there are plenty here who feel the opposite way
This is not very helpful, is it! Sorry
soundcloud.com/thecolourbox-1
As others have said, it’s far too loud for home if you crank it, so for crunch sounds at low volumes you need pedals or/and an attenuator.
Whether it’s loud enough for jamming or small gigs depends on your band and location.
Feedback
But my oh my - lovely Fender CLEAN tone at a usable home volume. The reverb is ....LUSH....
An amp I don't think I'll ever part with - I can't imagine Fender ever improving upon it.
Others have said they can get it to crunch but in common with other NMV 5 watt valve amps I've personally found to do so you'll be damaging your hearing and rattling your windows...so I use something quite different at home for rock etc...
(I'm not into pedals or attenuators at home).
I'd find a Princeton too overpowering for home use - and of no use for me with a band unless I was playing clean jazz.
Also, not being loud enough, the stock Jensen speaker is a limitation, with a decent upgrade (Ragin cajun for example) it’s actually quite loud for the wattage.
There's also the 'Stokes mod' for the circuit which improves the clean headroom, although I've never tried that on a reissue so I don't know how easy it is on the PCB.
Princeton running like that with a bit of reverb and that beautiful bias trem is one of my favourite sounds anywhere ever. And by anywhere I mean at home.
Possibly too loud to crank into full breakup at home (depending on your home) but I actually think a cranked Princeton sounds pretty bad anyway, it’s not a pleasant breakup to my ears at all….
My Princeton (Headstrong) plus pedals is my favourite home setup out of many previous and current options.
Nb, when I say Princeton, I mean 64/65 circuit. The recent fender “68” is just a different amp to my mind, not for the better.
TMDR FTW!
