I'd recommend a Boss RV5 or 6.
Works with a battery as well as a power supply and would survive being gigged.
Really small and does a decent hall/room/plate etc
The spring mode is close enough to the onboard spring reverb you get on amps and there’s nothing wrong with the plate, room or hall modes. I was also a big fan of the dynamic mode.
The only mode on it I didn’t like was the shimmer, which was shit.
On the cheaper side, I had a digitech x series digidelay (edit: Digiverb! What a plum.). It's nice! I think they're a bit unexciting but it was built well, cheap and added ambience without flash. A perfectly good, cheap, reverb pedal.
Polara was excellent.
RV6 is excellent
HOF2 was ok.
I still have the RV6, main gripe with the polara was that it was unreadable on the pedal in a gig situation. RV6 is only slightly better.
The stereo signal is brilliant – I made a stereo sniffer just to be able to record it easily – and church, reverse and spring get full marks. Spring is particularly unbelievable. Takes me back.
Jon
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
