I have a switcher that can be used to switch amp channels etc by sending a signal to ring and tip of a trs cable.
I want to activate the tremolo and vibrato on two origin effects pedals so I can control both from one output.
Is there a way to flip the signal sent to tip of a trs cable to ring so
tip < adapter > ring
ring > ring
Is there a cable I can use to do this?
Alternatively is there a splitter I can use to send the ring from the switcher to both pedals at the same time? As they are both in separate loops I could probably engage them both with one switch as one of the pedals would be out of the signal chain. So -
Ring < Ring
Ring
Does any of that make sense…? Thanks
Good deals with: handsomerick, majorscale, gassage, sticker, smudge_lad, anglian, edinfield99, thewiddler, thomfripp, notonlybutalso, JDE, chebellanga
If you're not up to soldering it yourself, talk to https://www.designacable.com/
