First tune it without the string under the tree, if it still pings, its not the tree, if its ok, then you could either try raising the tree with a longer spacer or try a roller tree, if it still pings then its likely a nut issue, (gut feeling its a nut issue as the b and e are smooth strings and should glide under the tree, fairly friction free) can the b and e move sideways in the nut slot? Possibly the nut slot is too wide and a bit rough where the string makes contact?
Strings can also snag in the nut when they are old and, heaven forfend, greasy or corroded.
What did you use to cut the nut grooves? This can happen when there's a small ridge in the middle of the bottom, so the string pings from side to side when you bend it.
If you don't have the correct rounded profile nut file, you can usually fix this by very carefully scraping the bottom of the slots from side to side with a sharp craft knife blade, making sure not to deepen them too much on the fingerboard side.
I have had a very gentle fettle, added some White Lithium Grease and some pencil lead shavings to the nut slots and given the Bigsby some welly, that seems to have done the trick.
I like the craft knife clean out idea, I'll do that next time I cut a nut or if the ping comes back on this.
