For the V7, it's good to explore the substitution in the context of a 251 because of the descending bassline, which is one of the things that makes it so effective: So, using Roman Numerals, in a ii-V7-I, you’re going to do a ii-bII7-I.
1) stick to the substituted chord's chord tones - Db, F, Ab, Cb (or B ). That's very basic, rather arpeggiated, but you can't go wrong.
3) Or over the Db7, you can sprinkle some G7 stuff as though you hadn’t substituted but that rather defeats the point, plus there’s a few notes you must avoid, like the D, because you’ve just moved off the Dm chord. Also I don't like the sound of the B or C there. The G, A, E, F are ok, plus you need to add the Db.
4) Or over the Db7 you play G(alt) notes, which are G, Ab, Bb, Cb (or B ), Db, Eb, F, G.
7) There's quite a neat trick Greg Howe showed me in a 251 in C; over the D, you play A minor pentatonic, to bring out the 2 of the Dm (the E); over the G7 (or Db7 substitute), you slip up a semitone and play Bb minor pentatonic, which has Bb, Db, Eb, F, Ab, Bb, which is perfectly in G(alt), as you can see from my 4th point above; then over the C you can slip up another semitone and play B minor pentatonic, which gives a lydian flavour to the C, as well as accentuating its major 7th (the B ). You just have to be careful to play purely pentatonic scales, no blue notes, just the pure pentatonic notes.
