Recommended place to buy 1 capacitor?
Hi there,
I need to get a 250pf mica cap 500V for my amp. I can find them on the internet, but although the cap is about £3 ish the postage charges are about £15 (or I have to buy 200 of them)
Can anyone point me to a supplier who can send me one and charge a reasonable postage cost?
Thanks,
Allen
  • CirrusCirrus Frets: 8563
    Try 270pf - basically the same, but more common.
  • If I want just one component I usually find eBay to be a good option. Lots of component sellers on there.
  • FunkfingersFunkfingers Frets: 15262
    Buy a larger quantity. Sell the surplus in the classifieds.
  • ICBMICBM Frets: 74475
    Why mica? If it's for a position with a substantial DC voltage on it - including the treble cap in the tone stack in most amps - then it will probably fail again at some point. I've noticed them being used in a few amps in inappropriate positions like this, and I'm not sure why other than a misguided idea that they're better. (It seems to be 'high end' amps.)
    Honestly any time I've been able to discern the difference between SM and Ceramic I've preferred the latter, but that's definitely taking the thread in another direction altogether.
  • allenallen Frets: 833
    Yes, it’s for the treble cap on a Carr Skylark.
    What type of cap would be better?
  • Modulus_AmpsModulus_Amps Frets: 2664
    Mica caps have been used for years and by many in valve amps that's why, there is a long history of use. Unfortunately there are good mica caps and bad ones, also the DC voltage rating is not the same as the AC voltage rating that is normally lower, saying that I have never had one fail in my personal amps but I don't have anything with very high b+ voltages and I solder carefully.
    The tone difference between them all is minimal IMO
    @allen, loads of places will sell you one cap, including me, RS components, Hotrox, hifi collective etc
    Polyester. Or a cheap ceramic if you want it to sound like an old Fender :).
