Personally I would stabilise what is there, with a view to replacing the binding totally if you ever need a refret. Some thin CA glue on the cracks should help.
If its celluloid binding then you can melt some scraps in thinners to make a binding glue that will melt into the cracks... but that won't work with more modern binding
Instagram
cheers for the info though WezV . I may even have a go at refretting while i'm at it. Worst case is a replacement basic neck from ebay. It's not my main player anyway, just a sentimental one
You can just trim it with file or scraper
Instagram
