I made a minor ouchy
digitalscreamdigitalscream Frets: 28098
edited February 2022 in Making & Modding
I'll leave you to figure out which occurred first.
On another note...have you ever seen that happen to a drill bit? I haven't. Well, until today.
<space for hire>
  • mrkbmrkb Frets: 7426
    Wow.
    Drill bits should be high strength but brittle steel. That’s either a cheap low quality steel or it’s been heated so much it’s annealed itself (which is unlikely)
    Karma......
    Ebay mark7777_1
  • Ouchy indeed. I've snapped many drill bits, but never bent one like that!
  • mrkb said:
    Wow.
    It's a cheap bit, but it also got hot enough that it almost burned a hole through the carpet after that incident.
    <space for hire>
  • m_cm_c Frets: 1274
    Cheap drills.
    I've also seen them unwind the helix.
    Work never bought from that supplier again.
  • BridgehouseBridgehouse Frets: 24584
    You can drill holes round corners now tho....
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • Devil#20Devil#20 Frets: 2136
    The only drills I bother using are Presto, Dormer or Guhring.
    Ian
  • BillDLBillDL Frets: 9013
    Did it go all the way through your thumb?
    I used to work in a precision engineering company and was standing beside one of the fitters when he drilled almost all the way through his thumb with the pillar drill press and the drill bit snapped off at the entrance hole.  He blacked out with the shock and sudden pain and later needed surgery to remove the broken piece of drill.
    So, what were you doing when the mishap occurred?  Drilling holes in a metal computer cabinet and the bit snagged?
    Nah, just surface damage as the bit bent and swiped past - the injury is far less impressive than the weirdness of what happened to the bit.
    I was drilling out the mounting hole in a Lace Sensor. Those baseplates are thick! Didn't use a vice because I didn't want to damage the plastic, and didn't use the drill press because...well, I couldn't be arsed getting it out of the shed.
    Lesson learned.
    <space for hire>
  • KittyfriskKittyfrisk Frets: 20586
    Wow, you were unlucky but lucky too, that could have been much more nasty.
    I wonder, did you buy the bits as being for drilling brass?
     Looks like the order was fulfilled as drill bits made of brass...
  • axisusaxisus Frets: 28397
    You are Superman and I claim my £5
