Power supply recommendation for expanding board?
HollowAxisHollowAxis Frets: 117
edited November 2015 in FX
  • FazerFazer Frets: 472
    i dont use that exact cioks, (got the ac10) but the range is top quality so go for it.
    and yes, you can power any pedal lower than the max per output, the pedals only take what they need.
    for low drain analog pedals like the comp and ods, you can prob use a splitter from one of the outputs if you need to squeeze an extra one or two in. the cioks will come with at least one 2/3 way splitter, check the contents and it wouldnt hurt to order another one when you order it.
  • HollowAxisHollowAxis Frets: 117
    Ah. Excellent!
    I was fairly sure that was the case, but doesn't hurt to check.
    Yeah' I think i'll be adding a Red Witch Fuzz God II to this setup at some point so it won't hurt to have splitters for low draw pedals.
    Thanks for the reply!
  • fretmeisterfretmeister Frets: 24909
    Gigrig Power Generator, distributors and isolators.
    oooo. that seems like a good thing ... Depending on how much it is.
    I'll look into this.
    Thanks
    Ordered the Cioks DC10, in case anyone cares :p
    The gig rig is awesome, I actually remember seeing a build video for Ed O'Brien from Radiohead, his board has that.
    Just a bit pricey overall if I want 3 isolators and the main box.
    I think the DC10 will do me well though. Even has some room for expansion.
