Advice looking for a replacement guitar
itmitm Frets: 1
I'm an intermediate level guitar student looking for a new guitar, but don't know where to start. I currently have an old Yamaha FG180 (red label Nippon Gakki) but I think it may have intonation problems (difficult keeping the bottom strings in tune when not played open). Having already spent £65 getting a setup and an issue with the nut resolved I'm now looking to trade it in for something that I'll find easier to keep in tune.
My preference is for something second-hand (don't want to spend more than about £80 if possible), and I'm based in Richmond in West London. I was wondering if anyone could offer any suggestions on models that would be worth looking at, and maybe any local dealers that would offer reasonable deals?
«13
  • ICBMICBM Frets: 72947
    My honest advice is to have someone else have a look at it - there's no way you'll get anything remotely that good for that sort of money, and there's no reason it shouldn't stay in tune (or play in tune, which is more what you're describing) if it's sorted out properly.
    In fact, you're unlikely to get anything that good for £180, let alone £80.
  • GassageGassage Frets: 31087
    I could let you know of a local dealer who'll offer a totally unreasonable deal and will be as rude as fuck to you just as a bonus
    Call Al at Chandlers.
    Never knowingly overly nice to anyone.
  • crunchmancrunchman Frets: 11504
    Al is fine.  Take into Chandlers and let the repair guys have a look at it and give you a quote if anything needs doing.
    As said above you are going to struggle to get anything properly good for £80.  At that price the only chance you would have is looking for a bargain on Gumtree or Feebay.
  • xSkarloeyxSkarloey Frets: 2962
    edited August 2014
    Nah. Call him instead to say you're taking it to Charlie's shop in Hampton Wick.
    That is a seriously nice guitar you have and it's worth a second opinion. But if you are looking for something new try Guitar Guitar in Epsom. Big range.
    One more from me: Ritz music opposite the Red Cow are always very nice to deal with and stock the Tanglewood range plus a few others. They only sell new. The Putney branch may have 2nd hand stock.
    Nice folks and a total absence of attitude.
  • itmitm Frets: 1
    Thanks for all the feedback. When I had the neck/nut done at Guitar Aid in Putney they said that the body had become a little warped, and said that they'd put electric strings back on it as a consequence, to avoid putting too much stress on the neck. If the warping is causing the problem (which sounds likely?) then is it likely to be economical to repair?
    Thanks for the recommendation re. Ritz Music - that's not far away so I'll pop in over the next couple of days.
    That should already have told you they don't know what they're doing!
    I'm assuming they put 9s on it? Since you can get acoustic 10s...
    9s are too light for an acoustic and will cause intonation problems because the guitar - and its bridge position - was designed for heavier ones with a wound third string.
    If the body has "warped" (or bellied, which is what this is usually called), it *may* make it difficult to lower the action far enough - this is quite common on old Yamahas - but has no bearing on the stress on the neck.
    In that case it's usually possibly to shave the bridge down a bit - the whole bridge as well as the saddle, if necessary - which will lower the action and reduce stress on the top. Even this should be within your budget of £80.
    The worst case is that it may need a neck re-set (ie to change the angle it meets the body at), at which point it does probably become uneconomical, but I would find someone who actually knows something about acoustic guitars for a second opinion before worrying about that.
    Don't trade away your nice old Yamaha for an inferior newer guitar when you can almost certainly fix it for less!
  • Paul_CPaul_C Frets: 7913
    edited August 2014
    if it is the top that's the problem, you could also try one of these - http://www.jldguitar.net/warped_tops/fixtop.html - I've fitted a few over the years and they've always worked really well.
    Stewart MacDonald sell them - http://www.stewmac.com/Luthier_Tools/Tools_by_Job/Bridges/JLD_Bridge_Doctor.html
    That ain't good.
    My advice would be to discuss it with Charlie Chandlers in Hampton Wick and at least get a quote for the job. Ritz Music in Putney also have a repair dept.
    That's a good idea. It might resurrect one of my old guitars. Fanx 4 posting.
  • itmitm Frets: 1
    Maybe it's worth me trying some heavier strings first? (I think the current ones are 9s or 10s but can't tell). Any recommendations for what to try?
    That's providing there's no danger of worsening any body warping by trying it?
    Unlikely. They go that way over a very long time - obviously the string tension is the underlying cause, but it's nothing that's going to get worse in the short term just from putting slightly heavier strings on it. These guitars were built to take at least 12s and 13s, which were the normal gauges back then.
    I would try at least some proper acoustic 10s to start with, or possibly 11s - 11s tend to have heavier bottom strings which will probably help the intonation. It might even be worth trying some with a 'piano wound' ball end, which is where the outer wrap doesn't go all the way to the end, and can intonate better - I'm pretty sure someone I knew with an old FG180 used Rotosound Country Golds on it for that reason. They give a very slightly lower action too, because the wrap sits slightly below the top of the saddle.
  • GruGru Frets: 339
    I tried a bridge doctor on my old laminate acoustic and it made a huge difference. It went from almost unplayable sunken brigde, to playable with a pretty level top. I am sure if I had taken it for a bridge and nut setup it may have amazed me even more.
    From a guitar I was almost going to dump, to one that I played for another 12-18 months before selling. The new owner is happy too.
    For very little outlay and some time, a little fiddly, but easy enough to do yourself.
  • itmitm Frets: 1
    Thanks. I've ordered some Rotosound Country Gold 11s from Fleabay so fingers crossed. I hope the larger bottom strings sit OK in the nut!
  • CloudNineCloudNine Frets: 4298
    edited August 2014
    Have had two FG180s and they can be great sounding. Playability with a poor neck angle can be really awful, particularly so on these. They are also the hardest necks to reset due to the type of glue that was used. A complete nightmare for even the best luthiers. I would personally get it converted to a bolt neck. I have heard about this being done with great results. Might not be that cheap, but you could end up with a killer guitar. I might pick up another one and get this done actually. So far, having seen about 20 of these, I have never seen one with a good neck angle. Any that were playable, it had been achieved through shaved bridges and other shoddy fixes. I think the necks were actually a bit under-set from the factory.
    The should be fine, the nut would have been cut for 12s originally - unless it's been replaced and the new one was cut specifically for the electric strings…
    I agree, except that a properly done bridge shave is not a shoddy fix. You do have to be careful not to go too far and not have enough depth left for an adequate saddle slot, but that's usually not too much of an issue unless the body has really got to the point of no return. In which case itm's original plan is the best!
    edited August 2014
    Take your point @ICBM, but it's not normally break angle over the saddle, or depth of bridge slot that is the issue with bridge shaving. It is the overall height of the strings from the soundboard that you are left with after the shave. It is that height which provides the torque to move the top.
    That is one of the most critical angle/measurements in acoustic guitars in my opinion. It needs to be round about half an inch from bottom of G or D string to the soundboard. I always think that is an essential factor in determining whether neck angle is correct and I always check it out on older guitars.
    In my view a bridge shave is NEVER the best option. Might be the cheapest/easiest, but not the best.
  • VimFuegoVimFuego Frets: 15769
    good post, thanks. I have my old acoustic which has just that problem and is almost unplayable as a result. I will try out one of those kits (got nothing to lose).
    I agree that a neck re-set is always the better/best option, but on this guitar it won't be economical. I doubt converting it to a bolted joint would be either. The bridge shave is the next least expensive and if done well will not make a huge amount of difference to the tone on an old ply top guitar - I've done several old Yamahas like this and the results have been quite acceptable. I'd agree with you that it's not a good thing to do to a top-quality acoustic, but in that case a neck re-set will be economical. I probably wouldn't even do the bridge shave until after trying a Bridge Doctor though. Start cheap, work up! :)
  • richardhomerrichardhomer Frets: 24864
    edited August 2014
    While I accept that shaving a bridge is not as good as a neck reset as a 'cure', if anyone has the Eric Clapton 'Unplugged' DVD, the close-ups of his pre-War Martin 00042 reveal it had had it done.
    Presumably EC could have easily paid for a reset and given it was a guitar from Martin's most revered period, it would have made financial sense.
    I can only assume he was satisfied with it the way it was.
