Re-use the existing selector switch and pickup output cabling. Use EMG block connector interconnection leads to configure the controls any which way you fancy.
Stock is bridge Vol., neck Vol., Tone. You could simplify to Master Volume, Master Tone and one of the booster accessories.
I'm considering trying the EMG Fat 55s eventually which come with a full solderless rewire kit so I may just get something cheap for now so at least it's not scratchy, then replace it all with the EMG stuff later on down the road. I was going to rip it all out for passives and still tempted as I know what I'm getting, but I'm not sure about drilling a ground wire to the bridge - maybe when I take it in for a setup I could get them to do it then.
The EC-401 has a sister model that is fitted with passive pickups and control parts to begin with.
Unless your example is exceptional, it would make more sense to simply change for another Eclipse.
I have not tried those. Hence, I can not comment on them.
My anecdotal experience is that the active pickups that come closest to the dynamics and tone of passives is Fishman Fluence.
I vaguely recall trying the LWC2 pickups in my EC-401. To begin with, they made a refreshing change from the ubiquitous EMG-81/-60 sound. After a while, I missed the slightly artificial, hyped-up tone of the EMGs but, for improved dynamic range, I bought the -X versions.
Are those Live Wire IIs interchangeable with EMG electronics without any hassle? As I said in my NGD thread these are all soldered pots anyway so I don't have the solderless stuff to worry about for compatibility. This guitar was so cheap that I don't mind faffing about with it for a bit to see how I get on.
The only possible hassle would be if you mix 'n' match EMG and Duncan active humbuckers. There may be a phase reversal issue.
