***SOLD*** : PRS S2 Standard 24.
Selling my PRS to fund something else.
Weight: 2.9kg / 6.6lb
Colour is "Vintage mahogany satin"
![Image: https://cdn.basschat.co.uk/monthly_2022_04/276036456_10159478940098726_5478928769201036528_n.jpg.ac582f1a1caf5f04e9431cc2f209de6d.jpg](https://cdn.basschat.co.uk/monthly_2022_04/276036456_10159478940098726_5478928769201036528_n.jpg.ac582f1a1caf5f04e9431cc2f209de6d.jpg)
![](https://cdn.basschat.co.uk/monthly_2022_04/276073694_10159478940048726_8941883208478602296_n.jpg.9f3a9deb124a925431af75d7687abfb5.jpg)
![](https://cdn.basschat.co.uk/monthly_2022_04/275955565_10159478939893726_2054819223745316947_n.jpg.f4c9ac42258cc5520a599107c3741db2.jpg)
![](https://cdn.basschat.co.uk/monthly_2022_04/276080401_10159478939938726_4093201543990116411_n.jpg.9b81c5acffeb9ada51985d2e0ccdcbbc.jpg)
![](https://cdn.basschat.co.uk/monthly_2022_04/276116526_10159478939993726_2560423437191064906_n.jpg.8839c1e07e1a97c7f2d39e012f0ac2f2.jpg)
I am the first owner - I bought it from Peach in November 2020 with a view to doing a load of recording. Then in December 2020 I ruptured a tendon in my right hand that only healed this Christmas so it hasn't had a lot of use and has never been out of the house. It was tuned B standard but is now back to E standard.
The little brass thing in the trem cavity is called a FU Trem Stopper. It's a simple device that is just a brass bracket with a screw and a nut to stop the screw from moving upwards. These are a frankly stupid £25! (also from Peach). It only stops up bends. I found it very useful for retuning to dropped tunings without needing to retune every other string or adjust the springs. It is easily removable as it's held on with 2 screws.
It has 2 humbuckers with coil taps with a push/pull tone control. The cavity cover and screws will be refitted before it is sold.
The neck is the Pattern Regular profile (the 2022 models are now Pattern Thin). It's very comfy indeed.
It comes with the gig bag that came with it, and the trem arm.
It's as well built as expected for a PRS. The fretwork is excellent and it stays in tune the way a Gibson can only dream about!
It's currently strung with Elixir Optiwebs.
I'm only selling because I'm a bassist and now that everyone is back at work I'm not really playing much guitar and when I do I've got a strat I've had for nearly 20 years. I'm not looking for any trades unless you've got a Sandberg California II VS4 passive bass that weighs under 7.5lb.
I'm looking for £675 or near offer.
Collection from Northants please. I don't have a guitar amp anymore so if you want to try it out plugged in, the best I can offer is a Roland Bass Cube on the "Bassman" setting for an almost Fender type tone. Or you can bring your own. Or bring a modeller to plug into the aux socket. Whatever is easiest for you.
thanks.
It is 'Vintage Mahogany"
Rhymes with Ecton
Kettering is often described as the K-hole
Sorry, that’s all a bit local isn’t it!
Don'#t be afraid to make an offer. I won't be offended.
Try me on trades if you like.
SOLD and GONE.
