Servisol leaves a very fine lubricant on the cleaned surfaces whereas the WD-40 electrical cleaner is just a cleaner and leaves little or no residue of anything after it evaporates. Bear in mind that these solvent cleaners are flammable while they are wet.
The secret to getting results is doing full rotations of the knob for a while after spraying. For particularly crackly pots that still crackle after spraying through the aperture in the body of the pot I have had good results by getting the solvent down the shaft side also. To do this I found some clear plastic tubing (formerly used for home brewing) that could push down tightly over the outside threads of the pot that come through the guitar body. Obviously this means you need to remove the knob from the shaft. I fit a short section of the tubing over the threads, wrap a cloth around the area just in case any leaks out or sprays onto the finish, and spray a bit of the solvent down into the tube. It should travel down through the gap between the threaded shaft and the spindle and you can use the tube as the knob to do your rotations.
