Glwts
Wish me luck
It worked very well.
Only gotchas were that the Tracker has the MIDI output and Line In switched off by default so you have to set them in the config.
The MIDI Chord FX works well which means you can get some extra polyphony for adding some pads without taking up loads of tracks.
I ran the audio of the Circuit into the Tracker, but going the other way might also be a good idea as you would be able to use the DJ filter and the better sounding limiter of the Circuit.
I was only using the synth voices of the circuit as the sample voices are way less capable compared to what the tracker can do.
