Hi everyone,
I've been meaning to ask this for a while, but I sort of got it fixed myself, except I'm not 100% sure (and I didn't ask at the time because my modem helpfully died at the same time, which is what forced me to sort it out myself
Am I right in thinking that with standard guitar wiring, you should get a multimeter reading of 0 ohms when your guitar volume is rolled down to 0? (I know, I should have taken a reading before I rewired it, but I forgot!)
How about with "backwards" wiring of the volume pot?- where the pickup hot wire goes to the middle lug, not the first lug. When I rewired my passive Fret-King PJ Bass (with standard passive bass wiring, one volume per pickup (backwards-wired) and master tone), I was getting a reading of "1" when the volumes were at 0, which I think means an open circuit (or over the maximum range, I guess). Is that normal? I'm getting normal readings when the volumes are up full.
Regarding how it sounds... I'm not sure. My ears are more used to guitar. I changed the pickups (and I also changed string type/brand)... my feeling is that before I changed the pickups, it sounded brighter, and the tone knob had more effect on the sound, but the new pickups are quite a bit hotter, so it could just be that (or a combination with the new strings). I also redid the wiring another 2 (!) times, and I'm still getting the "1" reading.
(What actually made me think something was wrong is that, the first time I wired it, it actually was sounding weird- the tone pot made a crackling noise when it was turned, and wasn't really reacting properly- a bit like when I didn't have the tone cap earthed properly on my Tele Thinline, so I thought I'd done something wrong with the wiring. But I'm now thinking the problem was just that some part of the tone knob or cap was grounding out in the cavity as I had sort of stuffed all the parts back in under the scratchplate. I then thought I'd use that as an excuse to change the pots... but they didn't fit (stock pots were mini ones and the cavity was routed to fit them). So I rewired it with the original pots (and a new tone cap, as I was worried I'd killed the old one bending it back to read its value), which adds up to 3 total wirings! Oh, and I was getting the same multimeter reading before I put the electronics back under the scratchplate, so I don't thinking something grounding out (at least in the cavity) is causing it.)
Thanks in advance for any help (and sorry for the length... hopefully it's just a "yes/no" answer to the resistance question!),
Dave
Certainly the reading should not be 0 with this kind of wiring.
What you said about the ranging being set incorrectly on the multimeter makes sense, I had the multimeter set to 20k (to measure the pickups' resistances). I'll hoke out the multimeter, change the range setting to a higher one, give it a shot and report back.
Just to clarify- I'm not getting the crackling with the tone pot now, that seems to be sorted. As I said, I think I just put it back together a bit clumsily, and something was probably grounding out or something like that. Thanks for the tip about the contact cleaner, though, I appreciate it
Also, where is the output jack socket located, relative to the pots?
Thanks for all your help
I don't have any photos, I'm happy enough if they say it should give me a resistance of half the pots' resistances, because that's what I'm getting. I thought it was possible that "backwards wiring" might make it give a different reading from normal when the volumes were at 0. All the other multimeter readings are normal, and I was probably just being paranoid about not being sure if the tone was right when I thought I had got an incorrect reading!
The tone pot shouldn’t affect the DC resistance at any setting, so if it does then it’s either wired wrong or the cap is shorted.
It wasn't all wasted work, though- now I know, and also I know I need mini pots.
Just out of interest- would you go log or linear for the volumes? I usually prefer log in a guitar, but in a guitar I'm rolling back from distorted to clean. On this bass I'd only really use the volume control to finely balance the P and J pickups in the middle position (which usually means a very slight roll off of the P pickup), so I'm thinking linear (that's what's in there currently, and it's working fine to my ears). (The tone pot is logarithmic, which seems fine too.)
(b) I don't think it is, I sort of got that from my Tele Thinline, where the tone cap wasn't grounded properly- and since it grounds through the volume pot, it meant it wasn't grounded properly either. I'm thinking the only problem was that I didn't put the thing back together properly and the tone pot or cap were grounding/shorting out against something. I think it's working ok now.
Thanks for your help
No worries, it wasn't confusing at all, I'd rather be safe than sorry and I appreciate the help. The more info you get, the more chance you have of solving the problem.
