SOLD Bogner Ecstasy Blue Mini
1. KSR Vesta - £300 delivered SOLD
"The Vesta™ contains a brand new set of voices along with a familiar feature set. Based on a couple of your favorite amps of the 80s and 90s, you’ll feel right at home. Picture a classic Crunch tone suitable for rock and blues, along with a familiar 90s high-gain sound. If modern extended range high-gain is your thing, the Ceres™ delivered. If you’re more at home on a 6 string, the Vesta™ may be your preference.
Its smooth, chunky, thick, and more low-mid focused. It takes boosts just like your favorite vintage high-gain amps. It responds incredibly well to the guitar’s volume control. Note: The Clean channel is identical to the Ceres’."
2. Bogner Ecstasy Blue Mini - £120 delivered
3. Metropoulos Supa-Boost - £150 delivered SOLD
"Metropoulos Amplification has introduced the Supa-Boost, a clean boost pedal that takes the boost circuit from the company’s MetroPlex amp, expands on the tube emulation and adds a “tweaked plexi tone stack” (treble, middle and bass).
According to Metropoulos, the Supa-Boost becomes like an extra gain stage in your amp, adding up to 20db of gain and frequency shaping to your signal before it hits the amp.
A custom-designed power supply converts a standard 9v tip negative (Boss style) power supply to high voltage to power the FETs. The pedal boasts true bypass operation and requires only 200mA."
