Looking for a bit of a steer from the hive mind on this one.
I’ve just bought the “TeleGib” body from
@maw4neu and it’s a beaut, I’m made up with it especially for the bargainous deal here did me.
The plan is to build it back up as a Jeff Beck type trib, The only slight niggle is that the routing for the bridge pickup is a tad over zealous and it just, just peaks out behind the rear edge of the humbucker ring, I mean sub 1mm. Now I’m sure I remember a few years ago having a slightly oversized humbucker ring. The holes were all in the same place as a standard one but the transition from the flat top to the vertical side was a bit more rounded than usual and so the footprint of the ring ended up being m marginally bigger which I think would do it. Anyone got any idea where I might source a couple of these with a flat bottom in Cream ?
I think those slightly weird Kent Armstrong pickups from the late 80s came with slightly oversized rings ?
I used the bridge height one on another build, and I have just checked the neck one, measures 46.5 x 92, but definitely wont swap for the cream one on the 54, not exactly sure what that is, but it is probably something vintage correct.
Might be worth a punt at Fake58?
I'm thinking abouot putting a Tele Gib together, although I'm looking at a Warmoth body and neck & it's going to be expensive!
