Hi
I'm after a little help. I've just opened the back of my Washburn X50Pro with a view to replacing the Custom Custom/59 combo with something a little cleaner. When I removed the cover the wiring was not as expected and I wonder if one of tFB experts might be able to advise.
I have another X50(a year newer) with two humbuckers that I upgraded myself and followed the SD diagrams. I have 2 humbuckers/1 volume/1 tone(push pull) and 3 way blade.
As you can see from the below, original X50 follows the SD wiring diagram. The red and whites both going to the tone/coil split whilst the green and earth to the back of the volume.
However, my recent Washburn X50 acquisition doesn't. In the 2nd image, the green and black are going to the push pull whilst
white seems to be getting grounded and the red goes to the switch.
Can anyone explain why there are differences and if I should just simply follow the existing wiring(i believe it is original due to the lack of solder everywhere).
Is it possible that when I've redone the pickups in the top I've made an error? If I have then I should change the red one(top) to match the amber one(bottom) Any help appreciated. Have I given enough info?
5 Guitars seems to be the magic number...discuss
Either scheme will work, depending on which coils you want to leave on.
IMO, reversing the order of conductor interconnection on one coil only makes sense to achieve hum-cancellation with the other pickup when both are coil split.
With DiMarzio twelve allen screw polepieces, it is possible to mount the neck pickup rotated by 180°.
I should have mentioned that, they operationally both seemed to work and the only difference was the coils that were split out. I had a custom custom in the bridge of each and they sounded different and I was concerned I'd bodged the wiring! Thanks!
Thanks @Funkfingers , would you suggest I wire the amber as per the red ie the red and white to the coil split pot? Is there a discernable difference between splitting the humbucker to the sound or simply for hum cancelling. It seems that the factory did it that way back in the day.
If you like the sounds of the red guitar, alter the amber guitar to match.
The only downside is that your white conductors are shorter than the others. You may want to trim the red conductors to match.
