It's probably divine retribution but last week I succumbed to impulse GAS and ordered a Peavey 6505 from GAK because a) I've fancied one of these for a while and b) it was very cheap in their sale.
They were out of stock for a few days but the amp has arrived in perfect condition and sounds great. The only problem is when I hook up my Digitech GSP1101 either in the FX loop or via 4CM, then there's a fairly loud hum which sounds very much like an earth loop. The level is constant and is not affected by having a guitar plugged in or not or by changing any gain or volume levels on either the amp or the GSP. I've not had much time to play around with it but I'm certain it's the FX loop on the amp.
I've used the GSP with 3 other amp heads and a combo (all valve) and never had any noise issues with any of them. I've checked all the cables, cleaned contacts, etc. but there's no change. A bit of interweb research reveals this to be a common problem with this amp and the 6505+ but there's a lack of sensible solutions. It seems to me that there's likely to be a design fault with the loop that can probably be fairly easily remedied by someone who knows what they're doing but I'd value some advice from the experts on here
@ICBM,
@ecc83 and
@jpfamps, if you have any experience of this problem. Thanks in anticipation ....
With the FX loop off but either send or return cables connected, there's a mixture of low level hum and crackling. With the loop on and cables connected there's a steady hum which is louder than most amps make (even the noisy ones) but still (just) useable. The noise gate on the GSP takes care of the hiss and any other noise but doesn't affect the hum at all.
Sorry to hear about the hum, interested to hear if you get it sorted.
It's far too loud (and noisy!) to use at home so, if I can get the hum sorted, it will be gigged.
I wouldn't argue with your much greater expertise but I'm still thinking there's an issue with the FX loop switching in the amp that is part of the problem and it may be exacerbated by the the Voodoo Lab switcher but, as neither the Peavey foot switch or my other two button one seem to work properly, I can't really test it.
The Digitech GSP is one of the quietest and most reliable bits of kit I've ever owned. I've used it with several valve amps as well as three or four rack preamps with both valve and SS power amps and I've never had any noise problems with any of it.
Thanks for your help @ICBM
