Quick way to cut XLR feed to monitors?
mrkbmrkb Frets: 6766
edited May 2022 in Studio & Recording
I’ve replaced my digital mixing desk and am using more monitor sends, and there’s now a loud pop though the PA when I shutdown the equipment.
Due to the way I’ve setup the rooom, there Isn’t an easy way to switch off the PA monitor power first. Is there a better / cheaper way than using a passive attenuator like the Palmer Monicon to cut the XLR  feed from mixer to PA?
Cheers.
https://www.thomann.de/gb/palmer_monicon.htm
Karma......
Ebay mark7777_1
  • WhistlerWhistler Frets: 322
    A different approach: our church has one power switch for all the musical equipment and PA. A clever solution has been two timer boxes which means when we power up, the PA speakers are powered up with a 30 second delay, and when we power down, the speakers go off immediately and the rest of the equipment shuts down 30 seconds later. I have no idea what the two little grey boxes are but it has silenced the thumpy-bang which bothered us for years.
  • RolandRoland Frets: 8677
    The manual option has two separate wall switches
  • mrkbmrkb Frets: 6766
    Thanks, I am considering that as well. Need to make sure moving the mixer onto the other socket (it’s a double socket) doesn’t cause other issues.
    Karma......
    Ebay mark7777_1
  • SnagsSnags Frets: 5354
    Do you still get the thump if you zero out the faders/sends before powering down?
    Back when I used to do the church stuff zeroing the desk avoided it. You could always tell who was paying attention :)
  • steamabacussteamabacus Frets: 1263
    Can you put a remote control mains socket on the PA power feed? They use radio frequency (rather than infra red like a tv remote) so don't need line-of-sight if the socket is hidden away behind stuff.
    Thump still occurs if everything is zerod - its a digital desk so think its a software power off crashing issue.
    Have temporarily fixed by adding another extension lead (the 6th ! in a tree branch fashion) which I can manually access and switch off when needed.
    Karma......
    Ebay mark7777_1
  • octatonicoctatonic Frets: 33779
    edited May 2022
    I would use one of these:
    You would need to change how you are powering the PA though and put it on one (or a few) of these switches.
    Thanks for all the suggestions - have found a solution that works if I switch on the double socket power in a Left to Right order and off in Right to Left - so happy with that. Though Octatonics solution looks better in the long term as it allows me to zone the music studio feeds - will check out a UK plug based version.
    Karma......
    Ebay mark7777_1
  • ecc83ecc83 Frets: 1617
    Another vote for wireless mains switches here. My living room system is a 40" TV, optical feed to a D/A box to an Arcam amp. That feeds a mixer associated with a MOTU M4. Mixer feeds 2 Tannoy 5As. The TV, amp and Tannoys all are controlled by a remote at my seating position.
    I have lights in my bedroom on a remote that also bangs on the kitchen light. Some wireless systems have a 'All On/off' button. Handy for me but not OP.
    Dave.
  • shufflebeatshufflebeat Frets: 104
    edited May 2022
    For the gig PA I have an individually switched 6way power strip, normal (UK) mains sockets. I have all the speakers running off one, desk off another, bass amp, misc (x3).
    Everything is labelled and any 2/4way that develops a problem can be swapped for another, no awkward connectors.
