I've been soldering for years, but mainly on circuit boards. I consider myself to be basically competent. I've been getting frustrated with a recent project because it has some panel mounted components with small, solid tabs - i.e. with no hole. Soldering advice is invariably "make a good mechanical connection before you solder" but I can't think of any way to do this in this case. My most successful approach is to generously tin both the tab and the wire and then hold the wire in place long enough to melt the tinning together, if you see what I mean. It works but is annoyingly finicky. Is there a better way?
U.
I don't always do what's recommended with soldering though. I don't like "making a good mechanical connection" usually as it doesn't make the solder any stronger and usually makes it a pain to remove again. Not had any problems so far!
I'd add that solid end contacts are hard to work with, but it is doable. Back when I did a bit of site work there was a standard connector for camera control that had 8 tightly-packed connectors (maybe 0.5mm apart) with no solder buckets, and in a thermoplastic carrier. Heat them too much and the carrier would melt so the pins would shift and the connector wouldn't work right.
All that in a very small backshell, and you had to get two jumper wires in too. I was very happy when I found little adaptor cables that turned them into a DE9.
