A mixer question, confused
I've got an XR18. I'm hearing reverb on my voice when I don't want to. I'm reasonably new to mixers so bear that in mind.
Here's the set up. Reverb on Bus 3 (send), stereo. Back in stereo on inputs 3 and 4. So now I've got reverb wherever I want it. In this case, keys (input 7 and 8 stereo) and voice (input 1 mono).
There are no inbuilt effects on.
Even with the Bus 3 slider full down I hear reverb. If I push it up there is more reverb as you'd expect. But how come there is reverb even with the Bus slider full down?
Any ides gratefully listened to, it's annoying me I cant sort it
  • StratavariousStratavarious Frets: 3673
    Pre or post fader send?
  • jackiojackio Frets: 132
    Hmmmm. Post. I wish I knew why you are asking  :#
    If the send is pre-fader it will still be there sending sound if you take the slider down.
    Is there a monitor/aux also sending to reverb?
    Ok. Reading now. Should it be pre-fader? Is that the issue here?
    I'm going to mess around with this now. Pre and post, monitor/aux and see what happens. Thanks @Stratavarious ;
    Sorted. I have the reverb send on Bus 2 and 3, not just 3. Thanks for giving me the way in to find it @Stratavarious ;
