WITHDRAWN Oil City Masterwound Djenerator Humbucker set with clear bobbins
For sale:
Masterwound Djenerator Humbucker set from Oil City Pickups with clear bobbins.
From the Oil City website:
“The Djenerator was made for those who like to tune low … then a bit lower. Ultimate chug with as much scream as you want thrown in. A super-sized ceramic magnet in the bridge position with a lower winding spec than you’d expect make for a pickup with brutal power combined with unexpected clarity and string definition. Using our two stage potting technique the Djenerator keeps an almost vintage tone till the gain is piled on … then it cuts loose.
The neck Djenerator is built to complement its hooligan bridge companion … clear and almost vintage … shimmering when used clean … it can hold its own under gain without becoming clogged and muddy.
Oil City ‘Masterwound’ range
Our premium series: these pickups take on the top boutique makers worldwide, and set a new standard for tone.
‘Using the finest materials and with the most exacting assembly each Masterwound pickup is hand made, serial numbered and signed, by me alone’.
~ Ash”
These have been mounted before but have tonnes of wire left and very slight signs of use.
4 conductor wiring so they can be split.
Bridge pickup is F spaced
13.7k bridge and 10.2k neck.
These are the “pro” version with additional shielding on the bobbins.
Mounting screws and springs provided.
Withdrawn
Please feel free to Dm me with any questions.
