1) Bridge HB only
2) Inner coils
3) Bridge + Neck HBs
4) Neck HB (Parallel mode)
5) Neck HB (Series mode)
It is possible that your switch has been physically damaged. Possibly by overheating, more likely that the lever and PCB are no longer making consistently firm contact. Heavy handed use introduces waggle in the lever.
One reason why things are not working is because you still have both bare steel "drain" ground wires wrapped around their respective green conductors.
On the DiMarzio version of the circuit diagram, a four-pole Superswitch is used. The neck pickup is intentionally installed the wrong way around and its conductors are connected in reverse order per coil.
I remember trying to wire this on a standard 5-way and could not get it to work (didn't realise at the time that the switches were different).
I think I used a diagram similar to this - https://i.pinimg.com/736x/9d/22/b6/9d22b6727b33d4025f021d1b5ce380a0.jpg
