Gadgets for removing broken strings
stufisherstufisher Frets: 887
So, last night I bust the high E string when playing my recently acquired HB DC junior. It was easy to remove so no big deal.
Tonight I bust the high E string of my Jet JS300 and I couldn't easily remove the string because the 'ball' end had got stuck in the guitar body.
I found a large, fat pin in a sewing kit and I was able to push the string through the guitar body with that, so ultimately all is OK.
This is the first and only 'through-body string' guitar I've had so I may just not know the vagaries of such but it got me wondering ...
Is there a specific tool/implement for this job?
If not, then what do others use to push strings through the guitar body when they are stuck/sticking?
  • thermionicthermionic Frets: 9785
    It sometimes happens with a Tele, and I’ll try pushing a new (thick) string through the wrong way - it usually gives it enough of a push to free the ball end.
    0reaction image LOL 1reaction image Wow! 6reaction image Wisdom
  • sev112sev112 Frets: 2864
    Knitting needle - everyone has got one of those…
  • BlueStratBlueStrat Frets: 968
    I keep a piece of a heavy string just for this
  • FunkfingersFunkfingers Frets: 14799
    The only things that usually make the ball end of a string stick in the anchoring ferrule are;
    1) Lousy through-body hole drilling.
    2) Corrosion
    3) The ferrule being made from "metal" that is softer than the string.
    Pickup height adjustment screws are not the only guitar/bass hardware that gets made of cheese.
  • KittyfriskKittyfrisk Frets: 19444
    I usually just use a long hatpin.
    A benefit of being a Jacob Rees-Mogg supporter...
    And good fun with a handgun?
  • ICBMICBM Frets: 73112
    The Allen key you use for adjusting the bridge saddles is perfect.
  • BigPaulieBigPaulie Frets: 1118
    It won't happen often enough to make buying or fashioning a specific tool worthwhile.
    Any of the suggestions above are perfect. I have used a heavy wound string in the past.
  • MusicwolfMusicwolf Frets: 3726
    This is what I do, except that I use the string that I've taken off rather than the new one.  I find that my Fender Strat is by far the worst for the string sticking.
  • stufisherstufisher Frets: 887
    Thanks all ... completely reassured that I still have some common sense left and my Jet JS300 isn't a wrong'n :+1:
  • HAL9000HAL9000 Frets: 9833
    You are Tom Daley and I claim my £5
  • prowlaprowla Frets: 5011
    Every musician has a set of Allen keys, right?
  • BodBod Frets: 1351
    Just restrung one of my guitars and 4 of the strings were stuck in the block, and this is the method I used with an old string.
  • guitarjack66guitarjack66 Frets: 1996
    I bought a Dunlop repair kit a while ago and it gives you tiniest allen keys possible,in length,so are pretty useless. There is a device that they attach to,like a sort of Swiss Army Knife thing but that fell apart not long after buying it. There also seem to be so many different sizes of allen keys that I'm not surprised if people dont,especially with older guitars.
  • OffsetOffset Frets: 12528
    I have to admit that in 45+ years of playing, most of it involving string-thru guitars, this is an issue I've never experienced...
